Best pipe for Raptor, and Edelbrock carb question
Old Oct 31, 2006 | 02:48 PM
TDK's Avatar
TDK
Default Best pipe for Raptor, and Edelbrock carb question
What is the best pipe setup for a raptor 660 that is bored with bigger valves and such. And will an edelbrock carb be any better than the stockers for a bored motor. I am asking because I can get a really good deal on one and I am kinda on a budjet. Thanks.
Old Nov 1, 2006 | 05:54 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
Dont waste your money on the edelbrock. Used 35mm FCR carbs can be found reasonable sometimes 39's. As far as a pipe setup the Barker exhaust is tops. From others experince the LTE comes in a close second. Sparks is prob the easiest to find single setup and works well. Call some builders they will point you in a good direction for your budget.
I have dealt with Craycraft and Barker both have been very helpfull with great customer service.
Old Nov 1, 2006 | 06:31 PM
Dwags's Avatar
i use a yousi exh and i love it. best #'s on the dyno
Old Nov 1, 2006 | 11:48 PM
duneittilludie's Avatar
I use the LTE duals on my 01 690 and they work very well for me.The Barkers seem to be a good choice from what i have heard but i dont have any experience with them.I do know that the LTE can be made fairly quiet and still perform well with the quiet core and i dont think that the Barkers give you that option.The stock Raptor carbs can really do a good job for you if they are jetted correctly.If you are on a budget then you may want to consider using the stock carbs and investing in a non o ring chain,lightened hubs,proper gearing,and the best tires you can afford to achieve big results with small$$$$.
Old Nov 4, 2006 | 01:05 PM
TDK's Avatar
TDK
OK so Im gonna get either the Barkers or the LTE. I know where to get the LTE, but can someone point me in the right direction for the barkers. Thanks
toonces
Oct 16, 2019 12:11 PM
tweeder
Jul 5, 2015 01:57 PM
D-Hagz
Jul 4, 2015 02:19 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
