Tricks for removing stuck axle nuts
Old Nov 19, 2006 | 04:44 PM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
Default Tricks for removing stuck axle nuts
IMPACT[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 19, 2006 | 06:41 PM
DriverDoyle's Avatar
IMPACT
How its on a axle nut??
Old Nov 19, 2006 | 06:47 PM
Speeddrive1's Avatar
Heat the nut cherry red, will not hurt the axle.
Old Nov 19, 2006 | 08:48 PM
Goodsound's Avatar
Originally posted by: DriverDoyle
IMPACT
Ooops.......I guess this is a perfect example of why you should read everything through before you reply[img]i/expressions/face-icon-small-blush.gif[/img]
When I saw "axle nut" I assumed the nut on the end of the axle that holds the hub. Thats what I always called the Axle Nut....my bad
Sorry.....never mind me
Old Nov 19, 2006 | 09:18 PM
  #15
recon99's Avatar
Thanks guys. I got it off this morning. Just needed a little more heat on the nuts, and they came right off. They were corroded on there pretty good. I'll probably throw some anti-seize on them when I put it back together, maybe that will help. But hopefully I won't have to do this again for quite a while.
Old Nov 19, 2006 | 10:40 PM
  #16
Good deal im glad you got it off..with out tearing anything up..
Old Nov 19, 2006 | 10:46 PM
  #17
fastblaster00's Avatar
get some g-force. its a general motors lubracint, works better than pb blaster. use that, heat it with a torch, BIG PIPE for ur pipe wrench. mine got stuck on my blaster and i just heated them. took about 1 1/2 hrs till i finaly got em off. when ya sit down and think about it its sad.... takes u over an hr to take of 2 nuts.... lol
Old Nov 19, 2006 | 10:48 PM
  #18
oh boy, thanks driver doyle, i indeed made a pritty dumb comment. i was thinking the completely wrong thing. now that i know what nut i am suppose to be thinking of, i would say get a pipe wrench on it, and then get a regular box wrench and use it for leverage. that will usually crack anything loose
It happens to the best of us...[img]i/expressions/face-icon-small-wink.gif[/img]
ya u can. just get a really deep socket. or a big crows foot. or just cut the axle down really short and use the gun lol
Old Nov 19, 2006 | 10:59 PM
  #19
recon99's Avatar
Wow, are you joking? I don't think any of those ideas would work. A 2 foot deep socket? An impact wrench on a crow's foot? Even worse, sawing off a perfetly good axle to remove the nuts?!? I'm glad you're not working on my quad lol.
Old Nov 21, 2006 | 06:12 PM
  #20
trialsrider172's Avatar
hey now recon, my idea was not bad, it works ALL the time actually.
