06 Kodiak won't start.....I've tried everything
Old Nov 25, 2006 | 06:44 PM
rovergrizz's Avatar
Default 06 Kodiak won't start.....I've tried everything
make sure the engine switch is in the ON pos...
Old Nov 25, 2006 | 06:47 PM
yamahalltheway's Avatar
Is there gas in the gas tank???? and are the battery wires on correctly?
Old Nov 25, 2006 | 09:20 PM
bombrider04's Avatar
Hondabuster I agree with you about the lean problem as it is getting close to winter time and its time to jet a little bit richer...But what kind of gas are you using in the kodiak and how long has the gas been sitting in the quad...Also are you sure that the fuel petcock is on the correct setting and is there enough gas in the carb...I would take the carb apart and make sure the jets aren't clogged up and does anyone know if these quads use a slide or a diaphragm in them...check over the carb very carefully because that sounds like it could be your problem if you just had it running fine the other day...the weather is changing so it is harder to start and will the quad run fine if you have the choke on
Old Dec 10, 2022 | 06:19 PM
TIB's Avatar
TIB
Hey Sonicpilz , what was the outcome to your quad not starting problem? I have an 07 grizzly and I have the same issue…
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
