450 Kodiak weird problems
Old Nov 24, 2006 | 02:39 PM
mcbuck's Avatar
Default 450 Kodiak weird problems
Hi to all, first time user of this forum. I have an '03 450 Kokiak and the battery has recently died, and I have yet to shell out the $75 for a new battery. I've been using the pull starter and it has been running OK until today. When at idle, the speedo reads 10-11 mph and increases with the throttle in park or neutral. I can run 35 mph sitting still! Also, everything is fine in forward and low range, but in reverse the motor starts cutting out. It will barely move and the motor sounds like it is about to die, but only in reverse. I don't want to take it hunting because if I get in a spot where I have to back up, I'm in trouble.
Any suggestions? Will a new battery mysteriously cure my problems or has running it with a dead battery screwed something else up?
Thanks for any and all help!
Old Nov 24, 2006 | 03:08 PM
captainkodiak's Avatar
It will do that if you do not have a battery installed. Being that your old one is still in the bike make sure all the connections are tight and it should act normal again
Old Nov 24, 2006 | 10:54 PM
mcbuck's Avatar
Thanks Captain Kokiak,
The old battery must have been completely, absolutely dead. Put in a new battery tonight and everything is right with the world again. Now for the those oil leaks on the left rear and both front output seals! Always something!! Thanks again!
Old Nov 29, 2006 | 02:10 AM
willieb76's Avatar
I have the same leak on the rear axel is this a common problen with kodiaks?
RedRancher
Oct 15, 2020 01:45 PM
chammerbeck
Jul 17, 2015 08:06 AM
Desimation2k8
Jul 17, 2015 12:37 AM
cSchwartz
Jul 12, 2015 07:42 PM
RedRancher
Jul 10, 2015 06:36 PM
