yamaha warrior need help my head pipe is glowing red
Old Dec 1, 2006 | 05:51 PM
tonester500's Avatar
Default yamaha warrior need help my head pipe is glowing red
hi guys and gals ok i put a used head and use carb on my warrior and the head pipe glows red and i mean real hot let me know the bike runs and strats right up no skips nothing i realy could use some help thanks tony
Old Dec 1, 2006 | 06:15 PM
recon99's Avatar
Sounds like you're jetted too lean. Take a look at the business end of the spark plug, on the ceramic insulator. What color is it? You want it to be a tan color, if it's white then you are in fact jetted too lean.
Old Dec 1, 2006 | 06:21 PM
dchicora's Avatar
I saw mine do the same thing already. Long idling, I think does it. I was playing with mine troubleshooting some stuff, and in the process I had it idling for long periods and the pipe got read hot like that. I think it can also be too much air. Running without an air filter or something. I don't think it does during normal use. But then again, I just bought it used and don't get a chance to mess around with it much.
Don't buy a warrior cd service manual off e-bay. It is only a pdf file on a cd that you can download for free from Sandwizards.com. Which I think is not accurate anyway. There are too many contradictions and poor quality pictures. The illustrated drawings look good, but the pictures are bad and you can't make everything out.
Old Dec 1, 2006 | 06:32 PM
that is the next ting i will do check plug and rejet the carb thanks
Old Dec 1, 2006 | 06:36 PM
no its when i start it up right off the bat it gets red all warriors do it with the ckoke is out to long but it leshould never do it at a idle
Old Dec 3, 2006 | 04:29 AM
cals400ex's Avatar
if it does it at idle then i would adjust the air screw. turning the air screw in make it a little richer at idle. if you need to turn it too much you may just one size larger on the pilot jet.
Old Dec 3, 2006 | 04:39 AM
cals400ex's Avatar
now that i think about it, i am not 100% sure if the warrior has a fuel screw or an air screw. 4 stroke CAN have either one. it will be a fuel screw if it is in the very bottom of the carb (it will face vertical). if it is an air screw it will be on the side of the carb (facing horizontal). however, to make an air screw more rich (more fuel) you turn it in. to make a fuel screw more rich you turn it out. so they have opposite effects. to make them leaner (less fuel) you turn them in the opposite directions.
Reactant
Mar 30, 2022 02:08 AM
Reactant
Jul 27, 2015 07:45 PM
traumajunkie
Jul 23, 2015 02:10 AM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
