yfm 250 starting problem
Old Dec 3, 2006 | 03:24 AM
vol98's Avatar
Default yfm 250 starting problem
1991 YFM 250b was idleing one minute then quit and wont start. Gas in airbox. Filter is clean. Took carb apart-cleaned-put back on. Still same problem. Motor turns over and plug is firing. Seems to have little compression (finger over plug hole). Has 130 miles on ring job. Could a valve be stuck, need adjustment? What else should I look for? If a valve, is there an easy fix?
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
