need help to adjust shocks
Old Dec 13, 2006 | 09:57 PM
bruinbill's Avatar
Default need help to adjust shocks
I need a bit of help. I'm trying to adjust the preload on the shocks on a 06 bruin 350 4x4. The spanner wrench available at dealer doesnt fit atv shocks. It had two sizes one way to big the other almost fits but cant get into a notch to adjust. Has anybody tried to adjust preload on their atvs? If so what type of spanner wrench fits?? Where can I get one?? I 've been trying to locate one with no sucsess. I really dont want to do the screwdriver - hammer thing. This would be fine for adjusting once, but I want to be able to adjust more than once. Thanks in advance, Bill
Old Dec 13, 2006 | 10:08 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
just use a hammer and screwdriver.. spanner wrenches are only good for wasting money.. along with about 50 other specialty tools you can buy from yamaha
Old Dec 13, 2006 | 11:15 PM
recon99's Avatar
what kind of adjustment is on your bruin's shocks? Is it threaded, or is it the kind that has a peg, and like 5 notches on the collar to select the preload?
Old Dec 13, 2006 | 11:57 PM
bruinbill's Avatar
it is the peg, with 5 notched positions, the quad didnt come with any kind of wrench to adjust, and when we looked for a "geniune" yamaha part none exsisted. So the riddle is do you just come up with your own idea on adjusting, hammer / big pair slip pliers...etc. or a tool that actually fits!!
Old Dec 14, 2006 | 12:03 AM
recon99's Avatar
That's what the stock front shocks on my warrior were like. Here's the best way I found to adjust them, and it worked very well for as simple as it is. First I jacked the front end of the quad up so the front tires were off the ground (i always used an old computer that was sitting in my garage). Then I just used a pair of channel lock pliers, but not on the knurled part where the spanner wrench is suppoed to go. I used them on the smooth part of the preload collar, and they turned surprisingly easy that way. Lifting the front end seems to help a lot by removing the weight from the springs.
Old Dec 14, 2006 | 10:46 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
You can use a pair of vise grips to do your adjustments. I wrap a cloth around the adjustment part and lock down the vise grips and turn it where you want it. The cloth protect it from being mared.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 14, 2006 | 12:50 PM
bruinbill's Avatar
thanks for the help, i'll give it a try with the big pair of channel locks and see if they adjust easy that way. thanks again
Old Dec 14, 2006 | 03:26 PM
BruinBasher's Avatar
Found my "spanner" wrench in my tool box. More widely known as a pipe wrench. Works great and ya don't chance slippin and strippin the collar like you would with channel locks or vice grips. In fact I carry it along with my other tools when I ride just in case riding conditions change enough I can stiffen or soften my suspension right there on the trail in a few minutes... Piece of cake.
Old Dec 14, 2006 | 06:55 PM
bruinbill's Avatar
hey bruin basher , thanks, that sounds like a good idea, and ive got plenty of pipe wrenches, even the special spanner edition left handed model...lol thanks again gonna give it a try.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
