top speed of 06 wolverine 350?
Old Dec 15, 2006 | 09:55 AM
YamahaWolverine350's Avatar
Default top speed of 06 wolverine 350?
i was trying to figure out the top speed of the 06 wolverine 350. I say around 55?
06 wolverine 350
raptor 80 (brother)
Old Dec 15, 2006 | 10:26 PM
recon99's Avatar
55 sounds reasonable, maybe a little lower depending on rider weight, tire pressure, etc.
Old Dec 16, 2006 | 12:00 PM
thanks man sound good to me
Old Dec 17, 2006 | 01:07 AM
xsmoker's Avatar
I doubt 55 but I could be wrong. My 450 hits the wall around 52 and I'm 210lb. It is possible that the lack of 4x4 helps the weight distribution enough to go faster but I doubt it.
Old Dec 17, 2006 | 06:55 PM
CTATV's Avatar
wait wolverine 350 4x4? 5 speed tranny?
Old Dec 17, 2006 | 07:35 PM
xsmoker's Avatar
No, not the 2001, the discussion is about the newer 06 350 automatic 2X.
Old Dec 19, 2006 | 09:47 AM
i got a 350 2x4 and i only weigh about 110. i havent put it full throttle yet because i just got it over the weekend. i just wanted to know the top speed.
Old Nov 12, 2012 | 04:36 PM
spittingmud34's Avatar
Default mph
i got my 06 yamaha wolverine 350 2x4 up to about 60 mph, i weigh about 90lbs. on rode and recorded 60 mph.
Old Nov 12, 2012 | 09:29 PM
DeathValleyReaper's Avatar
i would say around 55ish. maybe a little less. the wolverive wasnt built for speed as much as utility and recreational use. and the warrior will only do around 55 to 60 so the wolverine should be close or less, correct me if im wrong
Old Nov 13, 2012 | 09:02 AM
TLC's Avatar
TLC
The Wolverine has the same motor as the Big Bear and 350 Grizzly which hit 45 mph and 50 MPH in that order.
The Wolverine how ever is greared much taller and isa much lighter machine then those two ATVs and will do 55+ mph. Plus the Wolverine is turning much lighter 23" wheels vs the 25" wheels of the Big Bear and Grizzly.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
