2001 Yamaha warrior air filter
Old Dec 20, 2006 | 10:46 PM
kaylie's Avatar
Default 2001 Yamaha warrior air filter
Hello all,
I have a Yamaha Warrior and I am not to happy with the way the air filter is set up(does not seem to sit in the box to well and just seems loose). Anybody have any links to a good aftermarket setup that will help with this problem?
Old Dec 20, 2006 | 10:51 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
that's how the stock filter is.. aslong as the lid is on it is suppose to be held in there.. ssoo if u are messing with it with the lid off.. then that is your explanation..
Old Dec 20, 2006 | 11:02 PM
kaylie's Avatar
I am just unhappy with the design, once you close up the box who knows if the filter is sealed or not. Does anybody know of any good aftermarket options?
Old Dec 20, 2006 | 11:10 PM
Speedy2222's Avatar
to properly seal it.. put grease around the opening on the filter
Old Dec 21, 2006 | 12:01 AM
rruser's Avatar
What you want is a Pro Design airbox filter kit, or a kit from Noss machine. Both come with a billet flange and a choice of K&N or UNI foam filter.
Pro Design items can be found at most aftermarket atv websites or catalogs at dealers.
Noss Machine is at http://www.nossmachine.com/airboxkits.htm
Old Dec 21, 2006 | 08:07 PM
recon99's Avatar
agreed, either the kit from Noss Machine or Pro Design will take care of that problem for you. Just don't buy the "Hardstyle" clamp on kit from ebay, I did in june, and 5 months later i'm still screwing around with that ebay cocknozzle trying to get my money back.
Old Dec 22, 2006 | 01:06 PM
54warrior's Avatar
I bought my warrior new in 96, it has probably 2000+hours on it, and have had no problems with the stock setup. Sure, it's not the most user friendly, but as long as your careful when putting the lid on you shouldn't have any problems. Why don't you just live with it and put the $100 you'll have saved towards an exhaust system.
Old Dec 22, 2006 | 01:43 PM
recon99's Avatar
The stock setup is still restrictive though, so there is some power to be gained. Even if he leaves the airbox lid on, it'll still flow better. Have you ever had the airbox off the machine with the filter still in it? When the filter is properly seated, there is still at least a 1/2" overlap/mismatch between the hole in the airbox and the opening on the filter. That adds a lot of turbulance and resistance to the airflow. Take that airbox lid off and rejet, and there's quite possibly more power to be gained than an aftermarket exhaust, which will cost 2-4 times as much.
Old Dec 23, 2006 | 11:33 AM
kaylie's Avatar
Thanks for all the good suggestions!
Reactant
Mar 30, 2022 02:08 AM
Ashley S
Jul 31, 2015 09:46 AM
Reactant
Jul 27, 2015 07:45 PM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
