Need help on my blaster
Old Jan 22, 2007 | 06:32 PM
  #21
Boomer2's Avatar
Default Need help on my blaster
Yes it is cut the wires off and tape them together and your ready to go
Old Jan 22, 2007 | 06:58 PM
  #22
JLsparky7's Avatar
Originally posted by: ghettoblaster
can anyone confirm that the wire switch thing i pulled out of the throttle is the tors button or wutever it was held on with one screw
Yes that is the TORS throttle wire. You shouldnt have to cut it though. If you follow the wire there should be a quick disconnect type clip that you can undo. Same with the top of the carbs. Makes it look better and its more professional, not necessary though.
Something else just hit me. Sounds like you might have an air leak. Try doing a carb spray test around the carb and head. If you dont know how ill explain it.
Old Jan 22, 2007 | 08:28 PM
  #23
ghettoblaster's Avatar
yes an air leak is possible i am waiting for it to become warmer before i start fixing it... so where all do i have to cut/disconnect the wire?
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
