clutch problem ?
i was ridding my warrior around the yard today and every once in a while it was jolting .. like it poped out of gear.. but if thats what it did it went back in by itself.. then it made a bit of a grinding noise right before i put it away going from nutral to 1st? anyone ever had this happen before ? i hope its clutch related and not shift fork related.
i accidnetly posted this is the can am forum on accident .. so i put it in here now.. in the mean time i did notice something though.. i dont know if the reverse switch was in the right spot or not.. it goes about half inch last where it locks in to go forward but it doesent seem to lock in when you go past? is this normal ? where do you want to have this switch positioned? its to cold to go out there and try er out and see if that made a difference or not.. will have to check it out tomorrow .
