Any known problems with 07 raptor 700?
I plan on adding the LTE dual exhaust and K&N so far. You have to add a aftermarket intake also?? I was reading a little and prodesign seems to be popular. How good is the TFI that LTE makes for their exhaust? Is is good enough to handle mods??
If your going to put a K&N filter on it then yes I would get the proflo K&N filter & adapter kit and also an outerwear pre filter. You get rid of the stock adapter and backfire screen that is very restrictive. If your going to go with the LTE duals, I recommend the Power Commander PCIII EFI controller. I have a custom map for the LTE's and a PCIII I would be willing to share with you if you do decide to go that route.
