Durablue Axle question:
Old Feb 6, 2007 | 07:31 PM
Boosh71's Avatar
Default Durablue Axle question:
I have a Durablue Eliminator on my Raptor. The hubs and and axle-nut tend to loosen up every other ride. I was wondering if there would be anything wrong with using a lock washer with the hib nut. Maybe locktite? As for the axle-nut, I do use locktite on the set screw. I don't think the set screw loosens, but the entire unit. Is there any solution to this issue? Has anyon else had this experience?
thanks for any information
Old Feb 6, 2007 | 09:37 PM
JLsparky7's Avatar
I cant see a locknut or loctite hurting it. Call the manufacturer and ask what they reccomend.
Old Feb 6, 2007 | 09:46 PM
flyinscrammy's Avatar
My only experience with Duracrap axles was that the ones that they sent me didn't fit. Four times!!!!! I have nothing nice to say about this company and it's customer service.
Old Feb 7, 2007 | 05:57 PM
maddog56's Avatar
Wrong spline setup?
Never had this problem with a locknut, LSR is actually the one with locknut issues. I did have the problem with the hubs, but it's an x33 and I wasn't torqing them tight enough.
Is the axle old/used? May have worn out the threads over time and be shot, and in that case I'd ask for a replacement. Is the circlip coming off the groove or is the nut just getting sloppy?
Old Feb 7, 2007 | 08:52 PM
Polaris changed the rear axle in 03 making the housing a larger diameter. Duracrap sent me the old scrambler axle size, twice insisting that I was installing it incorrectly. THe little girl on the other line suggested that i have a technician install the axle. Fed up, I took the new Duracrap axle and my old bent OEM axle to an ATV shop in SLC, 100 miles from my house. Ordered, once again the correct axle....... No, not really, I got another one that didn't fit again. The shop and I used a micrometer and sent the exact measurements of the axle..... Guess what? Even after receiving the complete measurements they still sent the wrong axle, they assumed that Polaris had switched to using the Predator axle and didn't even bother checking the measurements that we sent. Bottom line, I have a new OEM axle.
Old Feb 7, 2007 | 09:27 PM
maddog56's Avatar
flyinscrammy, sounds like a horror story to me. I'd be pretty ticked off myself. They're almost entirely an axle company, changes like that are something they should be right on top of.
Old Feb 8, 2007 | 12:13 AM
On the bright side, I can change an axle in under 30 Minutes!!!!!!
Old Feb 8, 2007 | 12:57 AM
Boosh71's Avatar
The clip stays on there, I think the nut is sloppy.
Old Feb 10, 2007 | 01:29 AM
RayneSavage's Avatar
My wife agrees..........she hates sloppy nuts......[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Feb 10, 2007 | 02:09 AM
Boosh71's Avatar
haha
