Drive Train difference between 06 Kodiak 400 and 450
Old Feb 12, 2007 | 07:40 PM
GolfTomorrow's Avatar
Default Drive Train difference between 06 Kodiak 400 and 450
Could someone explain this, from Yamaha website?
450
Drive Train Yamaha On-Command? push button 3-way locking differential, 2WD, 4WD, locked 4WD; Shaft
400
Drive Train Yamaha On-Command? push button 2WD, 4WD ; Shaft
Old Feb 12, 2007 | 08:00 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
The main difference is that the 450 has a locking differential that will give you true 4 wheel drive whereas the 400 just has the three wheel drive with limited slip. They both have a 4 wheel drive button (truly 3 wheel drive) but the 450 also has a Diff-Lock button which is true 4 wheel.
Hope this helps
Buck
Old Feb 13, 2007 | 06:53 AM
Thanks, exactly what I was looking for.
Old Feb 13, 2007 | 09:11 AM
squeege's Avatar
Does the 400 come with low range as well?
Old Mar 23, 2007 | 09:04 PM
priesman64's Avatar
yup i pull some massive holeshots with mine in low gear but i wish it had the sensor like the Polaris 500 HO when it hit a high speed in low it kicked it into high
lightninboy
May 16, 2021 09:52 PM
RedRancher
Oct 15, 2020 01:45 PM
txpedsrt1
Feb 3, 2017 08:07 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
