Do I have to use specific injector oil in a blaster?
Old Feb 12, 2007 | 09:19 PM
bsb64's Avatar
Default Do I have to use specific injector oil in a blaster?
If I put torco premix oil in the injector tank will it work? Will it damage the motor?
Old Feb 12, 2007 | 10:03 PM
JLsparky7's Avatar
Most premix oils will work with oil injectiong. Thinner premix's will work better because the tube the oil is injected through is so small.
In all honesty your best bet is to buy a blockoff kit and mix your gas. Then you can get rid of the stupid little oil tank and not have to worry about your oil pump failing.
Old Feb 12, 2007 | 10:12 PM
bsb64's Avatar
Thanks for the reply....I have a lot of this Torco GPZ racing premix oil for a modded LT80.....I ran out of the yamalube, and was just hoping the torco would work in the injection system...It is a quality racing oil BTW....
Old Feb 12, 2007 | 11:10 PM
JLsparky7's Avatar
It will be fine in the blaster. Torco has been around for awhile and is a good brand. I would need to see the specifics on the bottle to know whether or not it was a "racing oil".
buddieboy
Dec 9, 2016 05:50 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
