Raptor rear brake
Raptor rear brake
Im replacing the rear brake pads....or attempting to anyways. Not too knowledgable about stuff like that, but im tryin to learn. I got the the caliper off and I got the old pads off. Now I have to push the piston back in a little more so I can get the new pads in. i tried to do it with a C clamp but was not able to move it. Am I missing something? How do i get the piston to go in?
Raptor rear brake
The rezzy is the brake fluid resovoir, where you put fluid in, the little tank that holds the fluid. I have used channel lock pliers to push the piston in before but a C-clamp works better. I have also had to loosen the bleeder screw on the caliper and then push on the piston to get the piston back, but then you have bleed the lines. It usually will go right in if you do that, but dont let the fluid squirt on you if you try this!
SixSpeed5
8
08-02-2015 05:38 PM
