Grizzly 660 head lights
Old Feb 14, 2007 | 06:13 PM
mikesg's Avatar
Default Grizzly 660 head lights
Has anyone had any experience or luck with changing the bulb? I think someone may have put mine in wrong because when I tried to change a half-burned out bulb, I opened the rubber seal from the back side, and then pulled off the connector, and the bulb just fell down inside the lamp. It is impossible to get a screwdriver into the inside of the rear part that holds the clear lens assembly on. Just wondering if anyone could gimme some tips as to how this thing can be taken out.
Old Mar 3, 2007 | 10:12 AM
BuckBlasterCanada's Avatar
I used the winch to lift the front of my bike up and it eventually sat straight up on end balanced on the back rack (turn fuel off first). I did this in my shed by hooking to the rafter, but I think a tree limb will do. Then using a step stool so I could see the bulb in the lens I jiggled it back into the hole and was able to extract it that way. This was the dealers suggestion as well. Just wondering if you run using both hi and lo beams at the same time? (by positioning the light switch in just the right spot). When you get the bulb out does it look like the solder has melted and let go around the ring?
Ray
greg74
Sep 10, 2019 03:03 PM
Jul 28, 2015 12:12 PM
ScopeZ_
Jul 28, 2015 01:44 AM
RticKwad
Jul 21, 2015 03:00 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
