Few new pics of the 350
Originally posted by: yamaharaptor350
Thanx bro... yea deff let me know about that webcam, lookin into that for my next mod
Yes you have to get stronger valve springs. The reason for that is, because with stock cam the warrior will float the valves if you rev it that far. So anything more then stock lift, duration cam you must do this. I don't know how Hotcam gets away with it. Most likely because they use a bunch of valve lash and there lobe separation with mild ramps.
I have Web's all around cam.. I'm actually waiting for my head and flywheel to come back from duncan racing. Once that happens I will fill you in. I'm in the process of a winter project. It will be really hard to tell though what just the cam will do because all of the things I'm doing to the bike right away.
I can tell you from a spec stand point what a cam will do and from this in depth engine program.
Originally posted by: 2FAST4URASS
Not trying to be a thread hyster but with the WEB CAM you do have to get the new spring's and how much power difference did you feel Jasonp ?[img]i/expressions/face-icon-small-confused.gif[/img]
Originally posted by: Raptor450
The first mods I did on mine were a cam, bigger valves, and a port job. I put it all back together like this while I waited for my piston to come in. I must say the cam and head mods made a HUGE difference. Then I installed a 366cc JE piston, which helped alot, but didnt add nearly as much power as the head mods.
