Change FRONT or REAR Sprocket on Raptor
I too run an 11 up front and it is nice, helps alot when riding tight trails can use 2nd and 3rd gear. It is always better to go bigger in the rear when you get down past a 13countershaft sprocket but on the raptor you cannot go to big in the rear unless you shim your skid plate down and then you'll loose clearance. The smaller fronts dont last as long but its worth the performance gain if you ride in the woods alot.
Bartolo, My 11 only lasted me around 1.5 months which to me is no big deal there cheap and easy to change only takes 10minutes. It would of lasted longet but I change them when theres alittle wear any pointing or bending. Thats 1.5 months of hard riding and not taking it easy which it would last alot longer, the 12 will last longer than the 11 and the 13 will last longer than the 12 and so on the bigger you go the longer wear you'll get out of them do to less revolutions/turns and less chan contact.
RticKwad
12
07-19-2015 12:22 AM
