Warrior Clutch Pushrod Clearance?
Old Feb 28, 2007 | 01:25 AM
son's Avatar
son
Default Warrior Clutch Pushrod Clearance?
Got a new clutch cover for my '99 warrior the other day. I need to know how far the pushrod is supposed to come out of the sleeve when the clutch lever is pulled all the way. Any help would be greatly appreciated!
Old Feb 28, 2007 | 08:41 PM
recon99's Avatar
It shouldn't matter, that gets adjusted after the cover is installed on the machine. Once the cover is installed, turn the clutch shaft counter-clockwise until the peg makes contact with the clutch inside. Then install the clutch arm onto the splines lined up between the marks that are cast into the cover.
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
