Blaster Boost Bottle
Old Feb 28, 2007 | 09:51 PM
04BlasterRider's Avatar
Default Blaster Boost Bottle
I have a blaster with the stuff on it listed below. I want more out of it power wise and more speed with a boost bottle be a good modification or not, i need some opinions or if any has one on there blaster. Also are they hard to put on.
I have a 04 blaster with the following:
-Reed Spacer
-K&N air filter
-14 tooth front sprocket
-Boyeson Pro Series Reeds
-Razr Rear Tires
-Tusk Nerf Bars
-CRJ Lowering Kit
Old Feb 28, 2007 | 11:56 PM
Airbrushhead's Avatar
It's a small difference. Easy to put on. I have a Banshee and Blaster. I noticed you didn't list a pipe. If you put on a FMF fatty and silencer that thing will come to life. Boost bottle helps with bogging when going slow then hammering it. Slight notice I think. Buy the cheap bottle like UM or Tusk, it's the same as the higher priced well known brands. I know. Pipes are the answer(night and Day)
Old Mar 1, 2007 | 04:29 PM
Ya i dont know how i forgot that, i have fmf fatty with a powercore 2 silencer, thanks anymore opinions.
Old Mar 1, 2007 | 06:47 PM
1988fast250x's Avatar
Heck you can go as much as u want.. 30mm Dslide carb works great... High compression piston with a 240 kit will def wake the thing up... if u want more speed go up 1 tooth on the front sprocket.. more dig but less topend go down a tooth.... if your bike has the stock suspention and A-arms on it dump those.. they really limit you.. might not seem like it but trust me! they slow ya down... aftermarket all the way you dont have to worry abt bumps and stuff and it really cuts down on the fatige (if thats how u spell it) those are some options.. any engine modds and u will need a carb.. call carb parts warehouse in Ohio.. they fix you up right!
Old Mar 1, 2007 | 09:30 PM
QWODER's Avatar
Do they make a boost bottle for a blaster?I never heard of one for a blaster.
panicmanic
Sep 28, 2015 12:59 PM
Ahtatu
Sep 28, 2015 12:14 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
