Warrior trouble? Cdi fried?
Old Mar 10, 2007 | 07:39 PM
greco400's Avatar
Default Warrior trouble? Cdi fried?
I have a yamha warrior 2001, the soloniod was bad, i got a new one from the dealer, befor i did that i bypassed the solonoid the qaud ran, anyways i put the new one on and the soloniod keep the starter cranking while the bike was running, and i shut it off, now i got no action happening to the soloniod and i got no spark i put a new fuse in and still no spark, with the soloniod bypassed
could i be the cdi any way to check i got no power going to the coil if that helps
please help
thanks alot
Old Mar 10, 2007 | 11:13 PM
JLsparky7's Avatar
Generally the stator and coil go out way before the cdi.
Old Mar 10, 2007 | 11:21 PM
greco400's Avatar
well the qaud was running with the bad soloniod, i went to the dealer got a new one and now i got no spark?
i used jumper cables from a other qaud to jump it due to battery had low voltage and wasnt cranking fast enough?
and now i got no power from the start button to the relay not one thing happens. the fuse is good all connections are good ?
Sparky i thank you, but i need to know how do you check the coil for being bad, i check to see if there was any power going to the coil on the wire but there is nuthing neutral light is on head lights work, just no spark and no nothing making the soloniod work?
Tips on checking coil, stator, cdi thanks alot??!!
Old Mar 10, 2007 | 11:28 PM
87warrior78's Avatar
for your coil you can do a ohm check you can find the way to test that and the stator and cdi in the manual you could also try to contact rickystator.com he will be able to help you test it and is a cheap place to buy one from
Old Mar 11, 2007 | 08:48 PM
greco400's Avatar
anybody know how to check the cdi?
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
Bernhard
Sep 25, 2015 12:45 PM
