Sparks Ign. Advance key - Rich Condition
I just wanna inform everyone that when you install the key it will make your bike run rich. I fouled a plug from this. Keep this in mind when/if you get an full exhaust 'cause you might not have to jet as high. I called Big Gun and he told me that I might not have to rejet at all with the full exhaust and my altitude. Keep this in mind if you wanna save a few bucks for different jets.(Don't wanna run too lean). I am going to install the headers and let everybody know what's up with the condition of the plug.
That stuck r.limiter could of been the problem. It also could of been other things. I took the carbs. off, along with cleaning the Air filter and P. Brake area. so I really couldn't tell you if that was stuck. It also couldv'e been the plug starting to foul. The machine was stock except for the ign. key. Maybe the 7 degree advance is too much? I only fouled one plug, although it was heavily sutted.
