yfz 450 wrist pin seizing
Old Mar 12, 2007 | 10:01 PM
YFZJayT's Avatar
Default yfz 450 wrist pin seizing
I was wondering if anyone has had a problem with there wrist pin seizing to the connecting rod due to a lack of oil. I heard there was a fix by machining an oil passage in the bottom end. Has anyone had this done? Any info would be greatly appreciated. thanks
Old Mar 12, 2007 | 10:33 PM
cluby's Avatar
Not saying this is what you did but one of the guys at work too his out on a lake and was playing around. That's what happened to his, called yamaha, said cause by an extense amount of high rpms and rev box installed.
Old Mar 12, 2007 | 10:39 PM
YFZJayT's Avatar
I have no rev box but always rev to the full potentencial ( not holding though) . I was at a small engine shop today and he had an 06 and 05 yfz in for repairs. the 05 showed lots of wear on the wrist pin and connecting rod and the 06 which had 10 hours on it already had wear on the pin and rod from the lack of oil
Old Mar 13, 2007 | 05:34 AM
JLsparky7's Avatar
Ive never heard of modding a wrist pin :-/
My first thought would be it is running low on oil or your using the cheap/wrong kind of oil. Ive never heard of this post before.
Old Mar 14, 2007 | 11:41 AM
garyc660R's Avatar
Huh? Just about every yfz engine failure centers around this issue. The wrist pin seizes to the rod and the rod breaks. If I were running a lot of extended high rpm use on a YFZ, I would call around and get advise from professionals (reputable engine builders) and go from there.
exmotocrosser
Sep 13, 2019 06:12 AM
1966F100
Aug 21, 2015 07:10 PM
joeyupton
Jul 14, 2015 11:51 AM
clsharky
Jul 13, 2015 02:07 PM
quadnob
May 29, 2015 07:25 PM
