pick up coil & source coil resistance big bear 400
Old Mar 21, 2007 | 11:56 AM
rockinrodtex's Avatar
Default pick up coil & source coil resistance big bear 400
i put old coil back on and got weak spark but only with spark tester on it. tested switches they check out good. now trying to check pick up coil resistance and source coil resis. i have a clymer manual. it says unplug wire at cdi and to check red to white with 459-561ohms. but there is no white wire. (thats for the pick up coil.) then source coil is the same but it says check brown to green. but there is no brown or green wire not sure if the book is misprinted or if i'm not testing it in the right place. whats the best way to test what else should i test.
Ean
Dec 19, 2022 08:48 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
ltrmc02
Jul 22, 2015 04:50 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
95wolv
Jul 17, 2015 08:13 PM
