Warrior help
hey. I have a 2001 warrior 350. i have put a supertrapp exhaust and a k&n airfilter on it. It was boggy so i decided to rejet. so far i have put a bigger 150 main jet in. i tried it out and it did run better. but it will still bogging and stall if u punch the throttle it right off an idle. so then i adjusted the needle and it is close now but it is still bogging only when you punch it off an idle. when u have the revs up then punch it it is fine. only bogs off an idle. does anybody have any ideas on what i need to do to fix this. thanks.
mine does the same thing, it has to do with the accelerator pump in the carb, i put a spring from a click pen in place of the stock spring in the bowl and it made a little difference, ive adjusted my carb every which way, that initial bog is there, i just deal with it. i have heard that the edelbrock carb helps this a ton, maybe even eliminates that bog.
