first atv..07 Wolverine 450...help with mods
Old Mar 27, 2007 | 09:35 AM
ctateusa1's Avatar
Default first atv..07 Wolverine 450...help with mods
The BMP cdi unit when available will probably(since its not out yet I dont know for sure) just raise the rpm that it will let the engine run and give the top speed another couple of mph.
I dont know if it will get rid of the reverse rev limiter ( I hope that it does).
But there is no real gains to be had by just the cdi, it will work much better with the pipe, filter, jet kit and possibly the EPI clutch kit.
I think that the cdi will be about 150.00
Old Mar 27, 2007 | 10:12 AM
u1arunit's Avatar
I think if the CDI has a revised timing map in it, there is a very good posibility that it could help somewhat by itself.
Old Mar 27, 2007 | 10:17 AM
ctateusa1's Avatar
True, but when I was talking to my local dealer, they said you will not notice much with it by itself, it is much better to use it after you have your other mods done, because you dont even hit the rev limiter stock(even at full throttle)
Old Mar 27, 2007 | 04:32 PM
samforbes's Avatar
well im glad that you all know things about all of this otherwise i would be in the dark...lol...anyway...thinks for the throttle limiter info....after i get my wolverine broke in ill let you all know how its goin...ive been having alot of fun on it the last few days...but its been mudy and snowy...but still fun..lol..thinks again for all the help.
Old Mar 27, 2007 | 04:52 PM
  #15
07Wolvey450's Avatar
no problem. just make sure you help out someone new when they need it, lol. and who cares what its like outside mud and snow is the best weather for fourwheeling. just make sure you wash it enough and keep it clean. wash it after every mud ride when you can if its above freezing.
Old Mar 28, 2007 | 07:50 PM
  #16
Widow317's Avatar
Also to add one thing..ive noticed other people having the same problem as myself...re-route the carb vent line to the air box...helps so much...poor wolvies sometime spit and spudder when water splashes up where the fac tory puts them..
Old Mar 28, 2007 | 09:14 PM
  #17
u1arunit's Avatar
When I re-jetted mine I relocated mine to the air box lid area. I made the one unused hole larger to fit the hose with a nice snug fit and put it next to the other vent tube that was there from the factory.
Funny thing is, I did this since I couldn't figure out where the carb vent hose was SUPPOSED to go after taking some stuff apart. lol
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
