more raptor problems
Old Mar 25, 2007 | 09:11 PM
hazardracing76's Avatar
Default more raptor problems
i have an 03 raptor with a fmf slip on with a quiet core and a k&n filter. a couple weeks ago i was racing a snow cross race when it just died. since then it will run good for a while then it acts just like it is out of gas. if i let it sit it will start back up and run for a while then start it all over again. I checked the jets, the floats, the petcock in the tank, and adjusted the valves. im not sure what is going on but need to get it going again any help would be appreciated. it has a full tank of gas and i also tried reserve.
Old Mar 25, 2007 | 09:56 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Check your fuel cap vent..........
If it's clogged it will not allow the fuel to flow into the carbs........[img]i/expressions/face-icon-small-smile.gif[/img]
Hope this helps
Old Mar 25, 2007 | 09:59 PM
tried that already
Old Mar 25, 2007 | 10:03 PM
CDI or stator going bad maybe???????????????
Does it seem fuel related or electrical related??????????
Old Mar 26, 2007 | 02:53 AM
rruser's Avatar
How long do you have to let it sit before it starts again?
Old Mar 26, 2007 | 08:19 AM
it seems like its fuel related, if i let it sit for anywhere from a minute on, and the longer i let it sit the longer it runs fine, it acts like its out of gas if it starts dying it will run all right as long as i back down the throttle untill its idling then it dies all together. I really appreciate every bit of info you guys give me.
Old Mar 26, 2007 | 07:02 PM
It's a head scratcher for sure............
Did ya check the carb boots for tears in um???????????
Are the carbs seated in the boots all the way?????????
Did ya check the slide diaphragms, IE seated properly, tears or small holes in um?????????
Is the choke/enrichner working properly??????????? Sometime that spring breaks and the enrichner gets stuck....
Check the jets for clogs??????????
That's all i can think of off the top of my head. Let us know what ya find. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 26, 2007 | 11:57 PM
wshrdskin's Avatar
Possibly a rectifier problem. It's the thing under the back of the seat. Gets hot, stops working etc. Next time it quits, touch it, see if it feels hot. This is just a guess. Not sure how you'd go about checking it to be good or bad.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
