Can't decide??/
I want to throw some spacers on the rear of my raptor but I can't decide if I should do 3" or 5". Any pros or cons to either one, does the 3" make a noticable difference etc? I am leaning towards 5" but how wide is too wide? plus I am not touching the front so will 5" be too much with a stock front end?
3" would be plenty. 5" would be too much if you're not using extended a-arms. It would look funny. Its not a good picture of it, but the photo I have called "still unloading", the 3rd bike back is a white & blue Raptor 660 with 5" spacers, and you can see how much wider it is than the front of the 450 behind it.
Well I would go with the 5 inch spacers because i put 3 inch on mine cause i also thought 5 inch would be to much but i can barley tell the difference but i would also work on getting plus 2 a arms also to make the atv more equal
well It would depend on what kind of spacers I was using, the 3 inch spacers are ok if they are stud spacers (better to have the full hub style though). I would not put the 5 inch spacers on in the stud style only the hub style.
This is just for safetys sake.
the 3 inch spacers only add 1.5 inches per side while the 5 inchers add 2.5 inches per side.
