Warrior - sputter sometimes backfire????
Old Mar 30, 2007 | 04:05 PM
scoop06pv's Avatar
Default Warrior - sputter sometimes backfire????
98 warrior, all i have is a supertrapp pipe and all i kno is tt when i bought it it had a sputter and it sounds like the timing is off or maybe the carb but i changed out everything in the carb, i tried a carb rebuild kit, and i even tried changing the needle up and down the notches middle being the best, it has a 145 main jet now, the kit came with a 120 which made things a ton worse, all i kno is IT IDLES FINE and even towards up to 200 rpm or so but thts all and than it sputter and i cnt gain any rpms.........help me i would really appreciate it !!!!
tyvm , John
P.S. the plug is carbonated (black) and dry
Old Mar 30, 2007 | 10:05 PM
dirtyblaster's Avatar
new plug? did u rejet
Old Apr 1, 2007 | 01:14 PM
recon99's Avatar
So, it's at idle, and if you hit the gas it seems like it just hits a wall, kinda like a rev limiter, and won't go any higher? Sounds to me like the parking brake switch is your problem, it sets a rev limiter at 2,000 rpm, about 600 rpm above idle, and they are known to be a problem on yamahas.
Old Apr 1, 2007 | 04:09 PM
scoop06pv's Avatar
u might be right i have to check tht today cause i can ride it around my yard jsut not hit the gas really....i thought it might not be the valves because it idles so nice and i can give it the tadest bit of gasss thanks for the help ill keep u posted...., john
Old Apr 1, 2007 | 05:07 PM
recon99's Avatar
I'm fairly confident that's the issue. Take off the headlights and hood, and follow the wires from the clutch perch down to where they plug into the harness. The parking brake switch will have a single plastic connector. Unplug that and your useless pb rev limiter is bypassed.
Old Apr 1, 2007 | 07:04 PM
scoop06pv's Avatar
lol its pretty funny how u asy tht about the parking brake cause it was already disabled lol im pretty certain its the valves now, John
Old Apr 1, 2007 | 07:14 PM
recon99's Avatar
it just seems really strange that it idles normally and won't rev up at all. Usually when valves leak it seems like the idling is the first thing that goes to hell.
Old Apr 1, 2007 | 10:12 PM
beaty's Avatar
i dont know alot about warriors but on the banshee u cant even give it eny gas with out bogging out if the parking brakes on
Old Apr 1, 2007 | 10:36 PM
scoop06pv's Avatar
so i tore the head off and the valves are in pretty bad shape lol so im gunna change them thanks for everything guys!!
ReconBayou
Oct 31, 2022 05:37 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
