trouble keeping it running
I have 660 raptor installed a new motor and transmission, and a new carabertor unit
It starts very good runnes good, after you run it hard it stops and will not start again is it the wireing or other problems ?
did you check and adjust the valves on the new motor? When it stops running you need to determine if its getting fuel and spark. Have a spare plug with you and when it stops you can pull the plug boot and put the spare plug in and see if there is spark. If there is spark then you need to see if it is getting fuel. could be a plugged fuel filter.
Big600twin
Jun 10, 2015 03:01 PM
UPLou
Jun 7, 2015 09:42 AM
