Problem w/ New FMF, Please Help Fast!
Old Apr 7, 2007 | 08:38 PM
lbwd's Avatar
Default Problem w/ New FMF, Please Help Fast!
I got an FMF Fatty Gold Series pipe and the FMF PowerCoerII silencer to go with it. I just installed it and when I start my 1999 Blaster, the exhaust sounds weird. It sounds like there's a bean in a can jumping around.
I am currently <u>uploading the video to YouTube</u> and I'll post it as soon as it is approved.
Any ideas in the mean time?
The only thing I didn't do, yet, is put the spring on.
I believe the sound is coming from the front, where the pipe connects to the motor.
Old Apr 7, 2007 | 09:24 PM
squeege's Avatar
Why didn't you put the spring on? Is it lost in the exhaust?
Old Apr 7, 2007 | 09:51 PM
lbwd's Avatar
I just put the spring on and it still sounds just as bad and leaks exhaust.
Here's the video: http://www.youtube.com/watch?v=LhUgh-1xS3A
Old Apr 7, 2007 | 10:11 PM
lbwd's Avatar
Do I need sealent, or to rejet the carb?
If I need to rejet the carb, how do I do it?
THatnks.
Old Apr 7, 2007 | 10:51 PM
07Wolvey450's Avatar
STOP RUNNING IT. you need to rejet your carb whenever you put a new pipe on... if you dont you will run it too lean and you will screw up your engine
Old Apr 7, 2007 | 11:02 PM
u1arunit's Avatar
It sounds perfectly normal.
Before you ride it you will want to have the carb re-jetted as was mentioned already.
If you don't know how or can't do it yourself have the local shop jet it properly for you before going wide open throttle. Running it at idle won't hurt anything though. When you go WOT is when you increase the load and need to worry about running lean.
Old Apr 7, 2007 | 11:11 PM
lbwd's Avatar
Thanks.
I also found this, for future reference to anyone who may need it in the future.
http://www.fmfracing.com/techsupport/jettingcenter.aspx
Ramman1
Jun 16, 2016 09:07 PM
Captjay
Jul 23, 2015 12:33 PM
JackTheKing
Jul 14, 2015 09:09 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
Jul 7, 2015 11:00 PM
