warrior help...no spark.
Old Apr 8, 2007 | 09:27 PM
mudking29's Avatar
Default warrior help...no spark.
i went off a ramp on my warrior and when i came down it died. there is no spark. i have tried new spark plugs. i tried checking for loose or damaged wires and connectors. i have found nothing wrong. there is no power in the orange wire going to the coil.i have read on here about starting problems with the parking brake but i dont know if that would be the problem. i have power going to the celeniod(starter relay). Would there be power at the coil with the key on? The neutral light comes on with key . Any help would be appreciated. Thanks!
Old Apr 9, 2007 | 12:41 AM
scoop06pv's Avatar
i would say ci or stator i just had a problem with my e brake and it still ran awesome u just couldnt rev it cause the having hte e brake on engages a rev limiter at 2300 rpm.....if theres no spark i would check ur coil first than hte bigger problems....pick one up off ebay there pretty cheap on there
Old Apr 9, 2007 | 02:23 AM
JLsparky7's Avatar
Check/Replace in this order. Are you sure its not getting a spark?
plug
Coil
stator
CDI
Old Apr 11, 2007 | 05:18 PM
philmagroin's Avatar
take apart kill switch jump circuit is that doesnt work change coil and boot if still nothing go for a cdi box aftermarket on ebay for a 100$ still nothing check the plugs off the stator with an ohm meter all should ohm out to zero if they dont ohm out let me know because im having the same problem went to local shop and the guy gave about ten pages of stuff to test and i can copy and mail them to you
Old Apr 12, 2007 | 04:51 PM
to let u know if it is the stator rickystator.com 150$ save you a couple hundred on one from a yamaha dealer
ultangler
Nov 30, 2024 01:35 AM
pgamboa
Dec 24, 2023 11:52 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
Bernhard
Sep 25, 2015 12:45 PM
