raptor a-arms
Old Dec 22, 2000 | 07:22 PM
dstevens's Avatar
i just got my ne a arms and my spindels need to be reammed any body know how to do this?at home?i took them to the machine shop and they dont have the correct tappered reamer, and advice would be appreciated
Old Dec 23, 2000 | 03:07 AM
dstevens's Avatar
i am not sure what size, they have a .50 taper at one half inch with a over all 5 degree angle , buragard uses automotive ball joints , so i realy don't have a clue of what to do , i will call a gut that i have raced with and ask him what he did , he owns a banshee. banshees have to do the same thing, so i am told.any help from you banshee guys???
Old Dec 23, 2000 | 08:53 AM
KyRaptor's Avatar
I am notsure which A-Arms you have ordered I ordered TimmyBoy Designs and they ream them for you for free. Lone Star will do them but charge you $40.
Both of these A-Arms require the spindles to be reamed. The taper on them is 1 1/2 inch taper per foot. The reaming tool may be purchased from Snap-On. The part number is R121.
Blue Raptor
Renthal bars
DuraBlue Axle+5
TimmyBoy A-Arms+3
TCS Shcocks
Fastline Brake Lines
Sparks Ignition Key (still waiting)
GYT-R silencer
Big Gun Head Pipe
ProDesign Switch
DG Front Bumper
Old Dec 23, 2000 | 06:28 PM
DreamDuner's Avatar
Hey KyRaptor,
Was there any trick to installing that DuraBlue Axle? I just got mine today and am trying to decide if I should take it to a shop. How long did it take and did you need any special tools?
Thanks.
Old Dec 23, 2000 | 07:15 PM
AZLandscaper's Avatar
Installing the axle is easy. Remove the spring clip and lock nut assembly from the durablue, and leave the other spring clip and retainer in place. With the old axle removed, slide the durablue thru the sprocket, and thru the axle housing. Slide the brake disc housing, then the lock nut assembly on. Finally install the spring clip and tighten the lock nut.
Nothing to it.
Old Dec 24, 2000 | 01:02 AM
DreamDuner's Avatar
Hey KyRaptor,
Thanks.
Old Dec 24, 2000 | 02:14 PM
dstevens's Avatar
Old Dec 26, 2000 | 12:17 AM
dstevens's Avatar
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
