Kodiak Help needed
Old Apr 12, 2007 | 06:10 PM
Ganggreen's Avatar
Default Kodiak Help needed
Crazy problem with this quad. Its an 03 Kodiak 400. When you connect the battery the starter continually is trying to start the engine even with the key and run switch in the OFF position?!! The only way to stop it is too disconnect the battery. Any ideas whats up?
Old Apr 12, 2007 | 06:19 PM
Honeyduck96's Avatar
Crazy...
Original starter, original install?
Old Apr 12, 2007 | 06:37 PM
Ganggreen's Avatar
Yep..Everything is original as it left the showroom floor. I should also add that the battery died awhile back and my buddy put the charger on it and possibly shorted something in the electrical system. Im guessing the starter solenoid is probably bad.
Old Apr 12, 2007 | 07:55 PM
cluby's Avatar
Ya only thing there is the starter solenoid that will cause this.
Old Apr 12, 2007 | 11:58 PM
buddah0012's Avatar
Starter solenoid is stuck in. With the battery disconnected put a meter on ohm and put leads to both large post. If it reads 0.00 ohms then the solenoid is stuck in.
Old Apr 13, 2007 | 11:11 AM
Ganggreen's Avatar
Thanks buddah...I tested it, and yes it is bad. Ordering a new one today
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
regrss
Jun 26, 2015 02:59 AM
Daryl Devine
Technical and How-To Articles
Jun 8, 2015 08:59 AM
