warrior help??????????!!!!!???
Old Dec 23, 2000 | 12:20 AM
warrior89350's Avatar
I need a good setup that will help with power on my warrior!starting with muffler all the way to the carb.can you tell me what will work for agressive woods riding.
Old Dec 25, 2000 | 10:40 AM
93warrior's Avatar
What I would do is get a WB pipe, K&N Power kit, 14 toothed front sprocket, and 20in tires.
crash.to/warning
1993 warrior
WB pipe
K&N power kit
spider trax tires
black rims
ceet grafics and gripper seat cover
teather kill switch
DG bumper
Old Dec 25, 2000 | 11:56 AM
scramdaddy400's Avatar
OK lets start from the intake, rip that good for nothing air box off and buy a K&N clamp on filter w/ outerwear to increase air flow.
Now you've incresed your air flow it's time to increase your carb. size go with CT Racings PE38mm/ Warrior carb kit to replace that lawnmower size stockie carb. (make sure when you buy the clamp on airfilter to measure the circumference of the carbs intake so you dont buy a filter with a clamp to big or to small).
Finally you need move this exhaust out as fast as possible to gain peak horsepower, go with the DMC dual exhaust system, this pipe and silencer combination delivers you the most usable horsepower while picking up power from the very bottom all the way to the top end.
www.knfilters.com
www.ctracing.com
www.dmc-on-line.com
Keep the tread side down!!!
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Dec 26, 2000 | 04:25 PM
RayWarrior's Avatar
If you want to build a woods Warrior, I would drop the front sprocket about two teeth, get a Webb cam, K&N stage 2 jet and filter kit, cut the airbox lid in half, and run an FMF header or Super trap. For a woods bike, you need something quick instead of fast, and all the power down low. A PE 38 would help a lot also.
99 warrior
01 Raptor
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
