Banshee Mod Quiestions
Old Apr 15, 2007 | 01:58 PM
Quinnsta's Avatar
Default Banshee Mod Quiestions
I have an 02 Banshee' and had a few questions about MODS
I keep reading about removing TORS System. What Advantage does this give you in the way of performence?
Also i know that many people think a boost bottle is a fancy piece of jewelry....any one have thoughts or good results with these added?
Finally how ofter do you need to replace the PETALS in the V-Force 3 Reed system?
Regards,
Ryan
Old Apr 15, 2007 | 03:27 PM
JLsparky7's Avatar
TORS stand for Throttle Override System. Its a electronic device that yamaha started adding to cut off fuel flow to the carb if they are stuck open. Good idea however it doesnt work, it has been known to accually cause the carbs to stick open as well as cause starting and reving problems.
Boost bottles are a waste of money, they do not do anything no matter what anyone tells you.
I would just replace the reeds when the break. Order some extras up and keep them on hand incase you need them.
What mods do you have done?
Old Apr 15, 2007 | 03:39 PM
kfxandahemi's Avatar
Yup, what JL said. Boost bottles are a waste, I change my reeds once a year, and ditch the tors. Stock carbs suck bad enough, and even more with that crap on there.
Old Apr 15, 2007 | 05:23 PM
Quinnsta's Avatar
Thanks for the advice.
Any TORS Kit Removal kit that you would reccomend?
List of Current Mods:
FMF Pipes with Power Core 2 Silencers:
V- Force Reed System
Uni Air Filter with Snorkel Removed
Works Front Triple Rate Shocks with Rezzie's
Holeshot Tires All Around
O-Ring Chain.
Anyhitng else i should do next?
Thanks,
Ryan
Old Apr 15, 2007 | 05:28 PM
Coolhead. They are a nice gain for not too much $$$. Check your Pms, I sent you some info.
Old Apr 15, 2007 | 08:23 PM
kawiking's Avatar
or you can have your stock head shaved,i have mine shaved down to .030(about a 20 dome).dont get a boost bottle !!!!! if you weight under 200,shave your flywheel it will rev alot fast.
Old Apr 15, 2007 | 08:41 PM
Quinnsta's Avatar
I weigh about 240 so flywhell prolly wouldn't work...
any ideas to give these more low end power?
Old Apr 16, 2007 | 09:41 PM
kawiking's Avatar
put a 13 tooth sprocket on the front.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
