warrior troubles !!!
Old Apr 15, 2007 | 06:51 PM
motion2000's Avatar
Default warrior troubles !!!
im having some wierd problems with my warrior.. for some reason i can not get the rear end to stay straight i get it so it looks straight .. or as straight as it will go.. then ride and it goes crooked throws the chain and knocks a hole in the case [img]i/expressions/face-icon-small-sad.gif[/img] fixed that but now i still cant figure out how to get it to go straight .. well i know how.. but it wont go straight no matter what i do.. wonder if the adjusters could be worn out or something ? i thought maybe the swimg arm itself is bent but it sure doesent look like it.. anyone heard of anything like this before ? thanks for any help
Old Apr 15, 2007 | 07:15 PM
recon99's Avatar
Start with both the adjusters all the way out. Then turn each one equal times until you get the tension where you want it. Then tighten the crap out of those carrier bolts. Tighten it to the point where you think you're about ready to break your ratchet. Once that thing is torqued down enough it won't move on you.
Old Apr 16, 2007 | 09:15 AM
54warrior's Avatar
Just be sure you don't over-tighten your chain either.
When tightening the carrier bolts, I've found it's best to use 6-pt sockets/wrenches instead of 12-pt. Especially on the lower one with the 14-mm nut.
Old Apr 17, 2007 | 01:14 AM
Raptor450's Avatar
Also make sure the axle bearings aren't worn out. Warriors are notorious for this.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
Bernhard
Sep 25, 2015 12:45 PM
