Raptor 350 mod question
Old Apr 18, 2007 | 11:31 PM
  #21
kyledvor61's Avatar
Default Raptor 350 mod question
Absolutely positively DO NOT EVER buy the drop-in k&n for the raptor 350. To start, they just re-labeled the warrior filter as the one for the raptor. They didn't work that well for the warrior, and it's even worse for the raptor, it doesn't even come close to fitting securely and properly. On top of that, because of the way they are built, the drop-in k&n's start falling apart after the first couple times you wash them. It won't be the same performance either. If you ever had an airbox off of a warrior or raptor, with the filter still in it, and looked into the outlet, you'd see there is at least a half inch of overlap so the airflow becomes turbulent and restricted all in one fell swoop. That overlap also leaves a spot where that foam seal just barely (talking like 2 millimeters on the edge) forms a seal against the box. Yamaha screwed up big on this airbox design back in 1987, and for some reason never did a thing to correct the problem. They probably figured they'd sell more replacement parts this way.
Good point. I dont like the airbox design either. If you are going to get the pro-flow kit then I would take the lid off while you are at it. But you will then have to rejet.and tell your brother to get a K&N!
Old Apr 18, 2007 | 11:39 PM
  #22
XRaIDED's Avatar
Beside the cleaning part. What are the differences between a K&N and a Uni OR that foam filter pro design?
Old Apr 19, 2007 | 01:25 AM
  #23
recon99's Avatar
I'm not sure if the foam filter that comes with the pro design kit is a brand name uni or not, but truthfully a foam filter is a foam filter, regardless of what brand name is on it it'll perform just the same.
Aside from the differences in maintaining them, it's a lot of speculation and personal opinions, so everyone you ask will say something a little different. Some say that the foam filters can hold more dirt, some say that they filter better, etc etc, but nobody has ever proven it, and i've never seen any evidence of dirt slipping past my k&n. The k&n is also going to be a more free-flowing filter because the air only goes through a couple thin layers of cotton fibers, vs the foam filter, which is first a 3/4" layer of coarse foam, and then about 1/2" of finer, more dense foam. Another thing I noticed with the foam filters, which annoyed me, is that it was hard to get your jetting right and keep it right, because every time you clean them they start this little life cycle over, where first they're more restrictive because of all the fresh oil in them, after half an hour or so the excess oil gets pulled through and burned and you're leaner for a while, and then as it begins getting dirty it grandually gets richer and richer again. I never noticed that with my k&n's as much, only when the filter got real dirty it would start getting rich, which you'll get with any filter full of dirt.
Again, i'm not real sure why anybody chooses foam filters, other than just getting their own opinion in their head and going with that.
Old Apr 19, 2007 | 01:29 AM
  #24
XRaIDED's Avatar
hey man thanks alot you've helped me out. Im going with the K&N. btw what lean= and rich=?
Old Apr 19, 2007 | 01:43 AM
  #25
recon99's Avatar
It can get pretty involved, but basically jetting is about shooting for the optimal air to fuel ratio that goes into your engine.
If it's too rich that means there's too much fuel (or not enough air), with that you get sluggish performance and carbon buildup, as well as it running rougher and sometimes hesitating when you hit the throttle.
Being too lean is the one you really have to watch out for though. Leaner (less fuel, more air) is faster (to a certain point) and is a cleaner burn, but it also creates a lot more heat. A machine that's too lean can start burning valves, melting pistons, seizing rings, and all that bad stuff.
That's why you have to rejet if you remove the airbox lid. You're allowing more air to flow into your engine, but the amount of fuel stays the same. Which means it'll be running leaner. So we replace the jet (which is a small threaded fitting with a hole in it to limit fuel flow). Put in a jet with a larger hole, and it'll richen the fuel mixture back up. The trial and error part can be finding exactly which jet you need to get that optimal a/f ratio. (then of course to make it more confusing, there's also different jets in your carburetor for different throttle positions) But that covers the basics for a newbie.
Old Apr 19, 2007 | 02:39 AM
  #26
XRaIDED's Avatar
lol i'll get the hang of sooner or later. i appreciate the info. Oh yeah hes now going to get the K&N lol i had to talk him into it.
Old Apr 19, 2007 | 09:47 PM
  #27
Jasonp's Avatar
I do agree with what you are saying and think k&n filters are awesome. I run a open air fliter setup and still ride in dusty and dirty conditions just really never through mud or water. I've always felt like that a foam filter with oil will filter better then a k&n type (this is only my opinion, also a foam filter will not reject water like a k&n with an outerwear). The k&n though will out flow the smurf out of a foam type and it's not even close that's a proven fact as in school we did a test on both of them on a flowbench. Huge difference. I've always seen fourwheelers stock set up with a foam type from the factory, where or not it's because they filter better or not I don't really know other then the fact they just might be cheaper...
Old Apr 23, 2007 | 01:25 AM
  #28
drewbiedoo's Avatar
Did you get a pipe, filter and jets yet? Just got my '07 raptor 350 and not sure what pipe to go with
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
