Please help asap with banshee fluid info
Old Apr 18, 2007 | 10:40 AM
nev's Avatar
nev
Default Please help asap with banshee fluid info
hello everyone. On the 2005 350 banshee i drained the cooling system by taking off the impella housing cover can i please ask when refilling the cooling system do i have to bleed the air out and if so how do i do it .
Also the gearbox oil where is the drain plug and how much does it take to refill
Thanks
Old Apr 18, 2007 | 12:07 PM
ClimbAnyHill's Avatar
You shouldn't have to bleed out any air from the cooling system. You can fill it, start it for minute. Air bubbles will rise. Let it cool & check your fluid level again. Add more if needed. If I remember correctly I think I used a quart & a half. Check your dipstick & don't go overboard on it.
Old Apr 18, 2007 | 03:29 PM
JLsparky7's Avatar
He hit the nail on the head. The manual calls for 1.6qts but 1.5 is fine.
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
slowgsxr97
Sep 8, 2015 07:33 PM
