banshee wouldnt shut off
Old Apr 18, 2007 | 11:13 PM
whseddon1's Avatar
Default banshee wouldnt shut off
i recently had my banshee running when i stopped the motor reved real high and wouldnt shut off i kept hitting the throttle and nothing happened so i turn both switches off and it kept running so i pulled the spark plug wires off and it still kept running so i shut the gas off jumped on it puit it in gear popped the clutch and it finally died i checked the slides on the carbs to see if they were stuck open and they werent they were moving fine then i pulled the plugs they looked a little rich i checked compression and both cylinders were at 135 psi only what happened now it starts and runs fine ??????????????????????????????
Old Apr 18, 2007 | 11:21 PM
klier's Avatar
Runaway Idle usually points to an extremely lean condition. I've had this happen on my dirt bike and yeah, you're about ready to crap your pants trying to get it to shut off. My carb to airbox clamp was really loose and it was sucking air. Check for air leaks. I assume nothing carb related has been messed with lately...
Also check the throttle cable just to make sure it's in good working condition.
Old Apr 18, 2007 | 11:23 PM
whseddon1's Avatar
no the only thing i forgot to post is that someone else mixed the gas when they borrowed the quad so maybe they didnt mix it right but yeah i almost soiled myself
Old Apr 18, 2007 | 11:28 PM
klier's Avatar
Mmm, I doubt it's anything to do with the way the gas was mixed. If no oil was mixed in at all, then it'd actually run richer. If too much oil was mixed in, it's going to run a little leaner than normal, but not enough to cause something like that...
Old Apr 19, 2007 | 01:35 AM
Doctorturbo's Avatar
GOT BOOST!
The only way to have a runaway is by having an air leak. You have an air leak somewhere. Could be a lot of places, but you do have an air leak somewhere.
Old Apr 20, 2007 | 12:18 AM
maxxedouty's Avatar
Does it happen hot and cold conditions?
lonerider856
Oct 13, 2023 03:45 PM
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
Matt123
Sep 29, 2015 01:29 AM
