'07 Grizzly 700 making noises :(
Old May 2, 2007 | 10:12 PM
JohnnySplat's Avatar
Default '07 Grizzly 700 making noises :(
Originally posted by: 07Grizzly
I had the stalling promblem it went away after 10 hours,I think the knock is due to the fact the piston is forged and not cast a forged piston is more dense and requires more clearence the noise should get better as the machine gets hot,the squeak is the exhaust flange give it some time to carbon up it should go away.ride it enjoy it .ps if you get low on fuel it stalls too,when hot you will hear a noise from the fuel tank worse when low on fuel it is the tank venting .
[img]i/expressions/face-icon-small-happy.gif[/img]
If it works out that way I'll be really happy. Also on the way home I had a thought about the stalling issue. If it goes away after a few hours that'd be great but if not I might try this...
You're probably familiar with the little FI programming trick for increasing power by telling the system to send more fuel to the engine. Well the stock setting is something like 60, with a max of somewhere around 200-250. The problem with setting it too high is that it causes the engine to be unstable and stall out sometimes. So, if it's stalling out at 60, would turning it down below that help?
Old May 2, 2007 | 10:21 PM
07Grizzly's Avatar
my grizzly is set on zero I tried going more rich,higher number,it ran really rich above 30.I have read a lot of posts about this and the numbers are all different best way to set the mixture would be with a air fuel ratio meter,next best thing is look at the spark plug if it is black it is too rich.I think your grizzly will be fine after 20 hours,mine runs a lot better about 30 hours on it now.
Old May 2, 2007 | 10:31 PM
Well then I'll just continue with my plan of getting through the break-in period and see what happens. If it all clears up that's great, and if not I'll take it in and have them take a look. Sounds a little better now though knowing this stuff isn't totally unheard of.
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
Bratman2
Jul 23, 2015 12:36 PM
hondarider1234
Jul 21, 2015 11:53 PM
D-Hagz
Jul 4, 2015 02:19 AM
