DEEP WATER STALLING WAT CAN BE THE CAUSE
Old May 24, 2007 | 09:46 PM
miassmaro98's Avatar
Default DEEP WATER STALLING WAT CAN BE THE CAUSE
HEY ON MY WOLVY 06 450 EVERYTIME I DRIVE IN DEEP WATER THE MOMENT THE WATER GOS OVER THE HEADLIGHT IT SHUTS DOWN ON ME AND SOME TIMES WILL START UP AGAIN OR MOST OF THE TIMES I HAVE TO PUSH IT TO LOWER WATER LEVELS TO START WHAT CAN IT BE?CAN IT BE THE COIL?I KNOW THE WATER COVERS IT.OR WHAT ELSE CAN IT BE?MOST OF MY ELECTRIC CONNECTIONS HAVE DIELECTRIC GREASE
Old May 25, 2007 | 09:12 AM
jkvette719's Avatar
I think I remember you saying you did but did you move the carb vent hose up into the airbox area? Mine hasnt done that, but i havent had it over the headlights much.
Old May 25, 2007 | 09:26 AM
yes i did
Old May 27, 2007 | 11:33 AM
not getting much help here
Old May 27, 2007 | 03:36 PM
texretvet's Avatar
I have an older ATV that stalls out when it gets wet. I was thinking it must be the electrical connections. Does dielectric grease fix this problem?
Sorry to but in on your topic.
Thanks.
Old Jun 3, 2007 | 09:18 AM
hey guys i was cleaning the wolvy the other day and i leave it run and wash it but when i spary water at the soark boot nothing but when i sparyed degreaser on the boot it shyt down?turn it back on water and degreaser and didnt turn off so i think i have to find a way seal the boot wat can i do
Old Jun 3, 2007 | 04:20 PM
CustomBLASTER52's Avatar
i have a blaster with no air box just direct connect to the carb with a k+n precharger black cover whatever its official name is and i stalled going into a very small stream not deep but it did make a big splash, if this happens again should i not restart it for a while or what, i did after ten minutes of kicking the *****er and it was fine after being boggy. Did i damage anything, im afraid of water getting into my motor but i was deep in the woods and had to get out????????????
Old Jun 10, 2007 | 04:29 PM
wxpnwo's Avatar
miassmaro did you ever get problem resloved? My wolverine is starting to do the same thing. Which hose is the vent tube on the carb? Is it the one on the left side of the carb above where the fuel line is?
Old Jun 10, 2007 | 11:31 PM
yes thats the one
Old Jun 11, 2007 | 04:52 PM
wxpnwo's Avatar
did you ever resolve the problem?
Pehter
Oct 3, 2024 11:00 PM
Customer Service #1
May 15, 2020 08:46 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
