why remove t.o.r.s. on blaster
Old May 27, 2007 | 11:08 PM
tatntj's Avatar
Default why remove t.o.r.s. on blaster
why would you remove it and how do you if it a benifit?
Old May 28, 2007 | 03:45 PM
JLsparky7's Avatar
TORS stands for Throttle overrider system. Its supposed to shut the fuel flow off if your carbs stick open. Basically, it fails causing high rev problems at idle and hard starting problems. You also might want to remove your ebrake components. They will cause your bike to hit the rev limiter when you are trying to go WOT.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
