replacing warrior front sprocket
Old Jun 6, 2007 | 08:54 PM
woodsrider823's Avatar
Default replacing warrior front sprocket
Just replaced my rear axle bearings and why i had everything off I decided to replace the chain and both sprokets. I have everything apart still but I am having trouble getting the nut off my front sproket. Even in gear when I try to loosen the nut the transmission just slips. Is there an eay way to get it off? thanks
Old Jun 6, 2007 | 09:04 PM
bberck's Avatar
When I took my warriors off, I just had to get a really long wrench to get enough torque to break it loose.
Old Jun 9, 2007 | 06:27 PM
Does the chain have to be on or is my tranny just messed up and is slipping with pressure?
Old Jun 9, 2007 | 06:35 PM
NLWarrior01's Avatar
What I would do is to put the transmission in 1st gear for max. resistance, get a cold-cut chisle and a hammer and strike the nut a few times to break it free, it should just spin off with your fingers after that. The sprocket nut on my old warrior was only really on a little more than finger tight anyway. The retaining washer is what keeps it from backing off.
Old Jun 12, 2007 | 10:27 AM
54warrior's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: NLWarrior01
What I would do is to put the transmission in 1st gear for max. resistance, get a cold-cut chisle and a hammer and strike the nut a few times to break it free, it should just spin off with your fingers after that. The sprocket nut on my old warrior was only really on a little more than finger tight anyway. The retaining washer is what keeps it from backing off.</end quote></div>
What he said is spot on. I sometimes use a small pipe wrench as well.
Old Jun 13, 2007 | 04:52 PM
lucasislight's Avatar
yeah make sure the retaining washer is flattened all the way and if you still have trouble, a little heat will help things out. take a plumbers torch to the nut and it should come off easier. and like NLWarrior01 said, you dont have to torque the thing down, just snug the nut up when reinstalling, the washer will keep it there. G/L.
Old Jun 14, 2007 | 12:11 AM
Raptor450's Avatar
An impact gun works wonders. I dont have one either, so I always take the nut off with it in 1st gear and hold the rear brake (with the chain on).
traumajunkie
Jun 30, 2015 04:28 AM
VRRRRT
Jun 27, 2015 09:38 AM
cornermike
May 27, 2015 10:04 PM
dosthoff
Jan 3, 2000 10:04 PM
caldwell
Oct 28, 1999 03:30 PM
