Yamaha 660 Raptor Problem
Old Jun 10, 2007 | 08:55 PM
InjunSHZ's Avatar
Default Yamaha 660 Raptor Problem
My brother has a 2001 YFM660RN Yamaha Raptor. We just changed out the clutchs in it yesterday. Now that we have done this, the machine will not shift into any other gear besides first. The shifter will move, but it will not click as if it is hitting any other gears. Can anyone tell me why? Thanks for any help.
Old Jun 17, 2007 | 09:26 PM
hondakilla4336's Avatar
hey i have the exact same problem with my 01 raptor.. i just put a new clutch in and the thing wont shift outa 1st. have you figured anything out yet??
Old Jun 19, 2007 | 06:40 AM
InjunSHZ's Avatar
My brother fixed it while I was at work. He said something about a pin inside of the case where the linkage hooks up. I will ask him for a more detailed account tonight, and report back later this evening.
Old Jun 19, 2007 | 02:45 PM
yeha i figured it out. it was a roller on a pin thing that fell outa place when i had the case off
Old Jun 19, 2007 | 09:40 PM
InjunSHZ's Avatar
Yup, that was it!! Glad you got it bud!
Old Jun 20, 2007 | 09:38 PM
antcomo's Avatar
can you tell me if i need to remove the water pump from the clutch cover in order to change the clutch??. its not that i dont want to pay to have it done its just i enjoy doing things myself , but just need some assistance along the way...
Old Jun 21, 2007 | 06:40 AM
InjunSHZ's Avatar
I remember when we took his down, we did remove the water pump, but it was no big deal. No gasket on that, just a rubber o-ring. If I remember, it was necessary to get at a screw to pull the cover. We also had to pull the front top and bottom engine mount bolts and lift the motor a bit, in order to pull the cover off past the frame.
Just remember to make sure that your clutches and plates go back on in the same order that you took them off. If I remember correctly, you will have 2 clutches smaller than the rest, and they go in specific places.
Old Jun 22, 2007 | 12:47 AM
antcomo's Avatar
thank you , thats what i needed to know, didnt want to go buy a gasket (oring) if i didnt have too.. thanks man, appericate it.. hey there are 6 springs right?? not five? they sent me 5 springs..
Old Jun 22, 2007 | 09:14 AM
InjunSHZ's Avatar
I think you are referring to the springs for the blots holding the Pressure plat, right. If I remember correctly, I think there was 5. We just reused the old springs. The only things we replaced when we were in there, were the Clutch Plates, and the Gasket for the cover.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
toonces
Oct 16, 2019 12:11 PM
Sjrpp
Jun 2, 2019 07:25 AM
yambam13
Jul 4, 2015 01:49 PM
