2006 Kodiak 450,Noise in Front Differential
Old Jun 11, 2007 | 11:39 AM
barrybabych's Avatar
Default 2006 Kodiak 450,Noise in Front Differential
Hello,
I have a 2006 Kodiak 450.It has approx 600 Kms.When I have the front end jacked up there is
a slight clicking noise when the front right tire spins.This noise happenings in 2wheel or 4wheel drive.
It doesnt happen when the front left tire is spun by itself.Sounds like the noise is coming
from inside the front differential.It almost sounds like it isnt disengaging something properly or a bearing
might be going.I have chk'd the fluid and no water has entered the differential.Has anyone else experienced this type
of noise on their Kodiak? Is it a normal noise or do I need to have it looked at?
Thanks for your time, Brent.
Old Jun 11, 2007 | 11:49 PM
awolff's Avatar
Is the noise coming from inside the boot connected to the differential? If so it might be your CV joint.
Old Jun 12, 2007 | 07:35 PM
JohnnyFentress's Avatar
I had that one time in my 05 kodiak turned out to be a stick between my brake and dust cover!!!!!!!!!!!!!
Old Jun 13, 2007 | 01:12 AM
power123456789's Avatar
You need to get it checked out before it causes any damage just in case...it is probably something very minor
Old Jun 13, 2007 | 01:55 PM
Thanks for your input JohnnyFentress, I will look closer into the brake area this weekend.
Old Jun 13, 2007 | 01:57 PM
Also thanks to awolff and power123456789 for your inputs,appreciate them.
Old Jun 14, 2007 | 12:29 AM
No prob man I hope its something stupid like that so your not out any cash! God bless!!!
Old Jun 15, 2007 | 12:51 PM
I was able to check a different 2006 450 and it makes the same noise, so all is normal.
Gtsordo
Jul 13, 2015 10:38 PM
tporath
Jul 11, 2015 12:31 PM
RedRancher
Jul 10, 2015 06:36 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
D-Hagz
Jul 4, 2015 02:19 AM
