small 05 blaster problem
Old Jun 15, 2007 | 04:07 PM
xxxalpinexxx80's Avatar
Default small 05 blaster problem
i just got a used yamaha blaster 05 and it runs really good the only thing that i dont know is if i kick start it it will turn on but i always have to tab the gas button really little so it wont shut off
if i dont hold the gas it will turn off in a second
i think the rpm needa to be adjusted if that is possible
Old Jun 15, 2007 | 06:13 PM
fastquad02blaster's Avatar
I had an 02, but I never had a problem with it not running at an idle. I don't know of any idle speed adjustment on it either.
Old Jun 16, 2007 | 05:06 PM
Dirt slinger's Avatar
Sounds like my 02 Blaster but mine would eventually idle after 30 minutes of running.
Old Jun 18, 2007 | 09:04 PM
mdebuck's Avatar
i have an 03 i usually have to pull the choke other wise it would shut down on me but after startin it and then turining the choke off after about 30 seconds of it starting it stays idle
Old Jun 23, 2007 | 02:34 AM
avenged10x's Avatar
your pilot jet might be clogged. i would clean out the carb. there is no idle adjust on the stock carb. you can buy a kit but it requires drilling a hole in the carb. After i put exhaust, jet kit, and a k&n on my blaster it wont idle unless i give it gas. But thats because i have a rather large jet in it. 2-strokes usaully wont idle until they are good and warm. Plus its always good to ride around a little right after starting it up so the plug doesnt get loaded up.
Old Jun 24, 2007 | 04:50 PM
TETuning's Avatar
Do the newer Blaster's not have the idle adjustment on the top part of the carb, under the seat?
Mine have it, and work fine. Screw in for higher idle. Even my 240 fully modded engine idle's fine.
Old Jun 25, 2007 | 12:27 AM
cway77's Avatar
I thought you could adjust the idle at the top of the TORS?? At least on mine you can but I am no sure how the 05's are?? Its a big screw that you can get at once you remove the seat right behind the gas tank on top of the TORS which is on top of the carb.
Frisky2050
Apr 9, 2020 11:19 AM
Captjay
Jul 23, 2015 12:33 PM
joeyupton
Jul 14, 2015 11:51 AM
steveo612
Jul 11, 2015 08:35 AM
black_thunder
Jul 9, 2015 05:58 PM
