ANY1 FOUND A CURE FOR THE WOLVERINE SPUTTERING PROBLEMS
<div class="FTQUOTE"><begin quote>Originally posted by: ctateusa1
the little fuel drain line on the bottom of the carb actually has a one way valve in it that I noticed today, I think that would work very good for the vent line if it will fit.</end quote></div>
okay so a one way vavle wont let nothing in but the line will still get clotted and you will have to clean or it still may suck up crap into the carb
it cant suck up any crap into the carb from the drain line because there is only one time when the drain is open(when draining the carb), so I think that if I move the one way valve to the vent hose then the one way valve(properly installed) will only let gas or air flow out of the carb and no into
#16
<div class="FTQUOTE"><begin quote>Originally posted by: miassmaro98
FOR ALL THE 06-08 WOLVY OWNERS WE NEED TO FIND A CURE FOR THIS SPUTTERING PROBLEM CAUSED BY THE CARB VENT LINE SUCKING UP CARP. IVE TRIED EVERYTHING, AND HAVE PUT THAT DAMN LINE IN SO MANY DIFFRENT LOCATIONS WITH FILTERS ON IT BUT NO LUCK, YEAH THE FILTER HELPS BUT IF IN DEEP WATER OR MUD TIME TO PUSH IT OUT AND CLEAN THE LINE.WHAT CAN WE DO I RIDE WITH A BRUIN 350 AND A GRIZZY 660 THEY BOTH HAVE VENT LINES BUT I GUESS THOOSE CARB DONT SUCK UP SO WHAT CAN WE DO?</end quote></div>
Sucking up CARP? Just how big IS that vent hose, and just where in the heck are you riding anyways? I've heard of Outlanders sucking up minnows and Raptors getting tadpoles in the airbox, but CARP?
