Vibration
Old Jun 19, 2007 | 02:00 PM
skylab's Avatar
Default Vibration
Hi I just bought a 2001 Kodiak 400 and was wondering if vibration from the belt/clutch area is normal? I can notice it at all speeds. I feel it int he hand grips-foot rests mainly.
Old Jun 19, 2007 | 05:08 PM
ATV_MAN's Avatar
Default Vibration
I haven't seen your quad but I would check the engine mounts, they could be cracked and/or damaged. How does it ride? can it get up to speed quickly? if not you might be looking at cleaning the clutch out and re-greasing and getting a new belt. After owning a Kodiak I know these Yamaha belt systems are near bulletproof, and easy to maintain.
Old Jun 19, 2007 | 11:19 PM
CraZySteve's Avatar
Default Vibration
it is Normal for the Kodiak/Grizzly 450's and I am sure the Wolfy 450's as well.. the 421 isn't balanced that well.. dealer says it is normal... so I figure since I got the 2 year extended warranty... if something happens it will happen in 2 years
Old Jun 20, 2007 | 11:17 PM
skylab's Avatar
Default Vibration
Thank you I just removed all the guards/ foot rest ect and looked at the belts, clutch ,clecked for run out. didn,t find any thing loose, motor mounts tight so I guess I will just run it and enjoy. I am used to a 225 3wheeler that has a shiter- no vibration at all, BUT Ok thanks again
Old Aug 11, 2007 | 02:26 PM
earlytimz's Avatar
Default Vibration
The vibration on the 400s are worse than the 450s, but it's completely normal and ok. I was concerned the same way when I bought my wifes 400, but it's not been a prob. Just ride the **** out of it, it'll be alright...
Old Aug 11, 2007 | 06:29 PM
skylab's Avatar
Default Vibration
Some of the vibration I found came from--of all things loose spark plug?????????not much but some- took it out and use hi-temp never-seaze. . Didn,t really stop the vibration, but it did stop have that vibrating sound--
Old Aug 11, 2007 | 10:43 PM
kyledvor61's Avatar
Default Vibration
If its got a warranty beat the crap out of it. Eventually you will find the problem (if there is one) and the dealer will fix it. (=
Dabears1983
Jun 23, 2015 04:59 AM
FireFighter
May 30, 2001 11:05 AM
ScoobyDFW
Apr 24, 2000 09:09 PM
Varso
Mar 14, 2000 09:46 AM
Hank
Nov 9, 1999 06:51 PM
